I've got an AC3 file, but there's only silence on the right, with all the sound being on the left. Is there any way to copy the sound from the left channel onto the right channel so it sounds decent when listening with headphones?
Results 1 to 11 of 11
I use audacity (free) for most audio work
make two L & R mono channels and shift one a few milliseconds
should give you simulated stereo -
Don't do that. Very likely it will sound WORSE!
Check your AC3 file with Audacity, (or other Audio editor that supports AC3), and see if VISUALLY it has only 1 track/channel. It could very well have 2 and your playback system has a short/open circuit on one channel.
If that's not true and you DO only have 1 channel with material (out of the 2 expected), I'd just copy the track so it'll sound in both ears and give you a phantom center. (This is AKA "Dual Mono")
If you were to do the delay trick, depending on the amount of delay, it'll progressively move AWAY from center toward the leading/earlier channel, until fusion is no longer possible because the delay is too long. Then, you'd get COMB FILTERING, giving you a hollow sound. If the delay were even greater, THEN you would have a minor spacious echo, but it would probably be annoying if having the same amplitude as the earlier channel (as that's not natural).
Guess what? - FAKE stereo sounds FAKE!
Scott -
Don't convert to mono, split it:
Open the AC3.
You should see two waveforms, left and right, and presumably one will be flat (silent).
To the left of the wave, click the little triangle next to the name of the file
You should get a bunch of options.
Chose "Split stereo to mono".
Now you have two mono tracks.
Delete the silent one. (Click the little x button on its left.)
You can adjust the volume now if you want. (Effect/Amplify)
Now do File/export and choose the format and rate -- you have to reencode to AC3, or MP3 or whatever.Last edited by AlanHK; 25th May 2011 at 12:17.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
Splitting 2 channel AC3 Audio
By jaesun in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2012, 15:41 -
Remove Channel from .ac3 5.1 audio
By 557953 in forum AudioReplies: 9Last Post: 22nd Mar 2012, 04:19 -
How to edit 6 channel (dolby 5.1) ac3 file in Audacity?
By siluet in forum AudioReplies: 5Last Post: 5th Oct 2010, 14:29 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
