Results 1 to 13 of 13
    Oct 2006
    I have some videos that came off my wife's handheld camera. I converted them to H264 with Handbrake - all of them on the same settings. I wanted to join them with My MP4Box GUI, and when I do they join correctly, but something is off on the time.
    If you view the properties of the created file the time is showing longer than the time of the original files combined. When I play the file back, it plays ok unless I scrub to the end - it just quits. So the entire video will play, but the end of the video is at about 75%-80% of the scrubber.
    Why is the time off like this and how can I fix it?
  2. what kind of "handheld camera" ?
    use mediainfo (view=>text) and copy & paste the info back here from a) the original file, b) handbrake encoded file
    maybe try joining the files before encoding ?
    Oct 2006
    It's a Kodak EasyShare camera - not a video camera. So it takes rudimentary videos. Here's the info from MediaInfo.
    Is it because it's VBR? Any why would the Codec IDs be different?
    ORIGINAL FILE
    General
    Complete name : C:\WP\100_2413-1.m4v
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 29.7 MiB
    Duration : 41s 6ms
    Overall bit rate : 6 075 Kbps
    Encoded date : UTC 2011-05-23 21:41:47
    Tagged date : UTC 2011-05-23 21:43:49
    Writing application : HandBrake 0.9.5 2011010300
    Video
    Format : AVC
    Format profile : High@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 40s 970ms
    Bit rate mode : Variable
    Bit rate : 5 936 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Frame rate : 29.534 fps
    Minimum frame rate : 29.518 fps
    Maximum frame rate : 29.537 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.654
    Stream size : 29.0 MiB (98%)
    Writing library : x264 core 112
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 41s 6ms
    Bit rate : 138 Kbps
    Maximum bit rate : 157 Kbps
    Channel(s) : 2 channels
    Sampling rate : 22.05 KHz
    Compression mode : Lossy
    Stream size : 691 KiB (2%)
    Tagged date : UTC 2011-05-23 21:43:48
    ENCODED FILE
    General
    Complete name : C:\WP\Kids.mp4
    Format : MPEG-4
    Codec ID : isom
    File size : 112 MiB
    Duration : 3mn 39s
    Overall bit rate : 4 298 Kbps
    Encoded date : UTC 2011-05-23 14:10:33
    Tagged date : UTC 2011-05-23 14:10:33
    Writing application : My MP4Box GUI 0.5.5.4 <http://my-mp4box-gui.zymichost.com>
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 3mn 39s
    Bit rate : 4 222 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Frame rate : 29.506 fps
    Minimum frame rate : 23.603 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.466
    Stream size : 110 MiB (98%)
    Encoded date : UTC 2011-05-23 21:43:49
    Tagged date : UTC 2011-05-23 14:10:37
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 3mn 39s
    Bit rate : 76.9 Kbps
    Maximum bit rate : 85.5 Kbps
    Stream size : 2.05 MiB (2%)
  4. VBR video rarely causes problems
    but VFR (variable FRAME rate) ALWAYS causes problems
    I think you made a mistake or omitted the original information. Post the mediainfo for the original file (ie. from the camera)
    If it shoots VFR, then you have a problem
    If it shoots CFR, then manually entering the FPS in handbrake or "same as source" should solve the VFR encoding issue, then they should join
    Oct 2006
    Nope, the "Original File" I posted is one of the original files (I think there were 5 that I encoded then tried to join).
    I've never heard of VFR. So how do you fix something like this. If I encode it with handbrake to a standard framerate, won't that mess up the video?
  6. Originally Posted by douga View Post
    nope. Look at the meta data , it says writing application: handbrake, and gives x264 settings
    I'm unaware of any camera that uses x264 for encoding hardware
    Post the mediainfo from the original camera file first. I think you made a mistake
    You can try converting to CFR, but it might not be necessary
    Oct 2006
    I gotcha now - I thought you meant one of the original files I tried to join. Here's the info from one of the AVI files off the camera. It's got a framerate of 29.533. If Handbrake is set up for the framerate to be "Same As Source", why is it ending up as VFR?
    General
    Complete name : C:\WP\Home\New folder\a\100_2413.AVI
    Format : AVI
    File size : 58.4 MiB
    Duration : 41s 4ms
    Overall bit rate : 11.9 Mbps
    Writing application : EASTMAN KODAK COMPANY KODAK EASYSHARE C195 Digital Camera
    DTIM : 2011:05:08 20:41:10
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 41s 4ms
    Bit rate : 11.7 Mbps
    Width : 640 pixels
    Height : 480 pixels
    Frame rate : 29.533 fps
    Color space : YUV
    Chroma subsampling : 4:4:4
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 1.294
    Stream size : 57.4 MiB (98%)
    Audio
    Format : ADPCM
    Format profile : U-Law
    Codec ID : 7
    Codec ID/Hint : CCITT
    Duration : 41s 3ms
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Sampling rate : 12.0 KHz
    Bit depth : 8 bits
    Stream size : 961 KiB (2%)
    Interleave, duration : 34 ms (1.00 video frame)
  8. Frame rate : 29.533 fps
    that is a very odd frame rate, and suspicious for VFR, but VFR isn't possible in AVI container
    If you have time to do some tests, I would manually try entering 29.97 in handbrake
    If that doesn't work, try manually entering 29.533
    Actually, before you try that, try joining the AVI files in virtualdub or avidemux first. If that's in sync, then encode with handbrake
    Oct 2006
    Thanks for your help!
  10. did it work ? please report back if it does or not, so other users looking to join "KODAK EASYSHARE C195 Digital Camera" files can get help as well
    Oct 2006
    Well, I tried using the standard 29.97 and it didn't work. The videos encoded and play ok, but when I join them I get the same result. When I select all the videos it shows the time as 3:39, but the joined one shows 4:54 and has the same issues when scrubbing.
    Next I'm going to try using the 29.533 framerate, and then I'll try joining the AVIs first, and then encoding.
    NEW CONVERTED FILE
    General
    Complete name : F:\PortableApps\HandbrakePortable\Data\Encoded\100 _2426-3.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 34.0 MiB
    Duration : 1mn 15s
    Overall bit rate : 3 782 Kbps
    Encoded date : UTC 2011-05-24 17:24:19
    Tagged date : UTC 2011-05-24 17:25:49
    Video
    Format : AVC
    Format profile : Main@L3.0
    Codec ID : avc1
    Duration : 1mn 15s
    Bit rate : 3 705 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.402
    Stream size : 33.3 MiB (98%)
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1mn 15s
    Stream size : 707 KiB (2%)
    Tagged date : UTC 2011-05-24 17:25:48
    NEW JOINED FILE
    General
    Complete name : F:\PortableApps\HandbrakePortable\Data\Encoded\Kid s.mp4
    Format : MPEG-4
    Codec ID : isom
    File size : 107 MiB
    Duration : 3mn 39s
    Overall bit rate : 4 097 Kbps
    Encoded date : UTC 2011-05-23 17:53:24
    Tagged date : UTC 2011-05-23 17:53:24
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 3mn 39s
    Bit rate : 4 022 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.437
    Stream size : 105 MiB (98%)
    Tagged date : UTC 2011-05-23 17:53:31
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 3mn 39s
    Oct 2006
    Ok, so here's a little more on this. got 3 new files I wanted to convert and join. I haven't had any success joining them as AVIs because for some reason something's funky with the audio in the AVIs and Avidemux doesn't like it. So, I've converted these and made them all 29.97 fps, but when I join them, the join file is still coming up as VFR. Here's the info from MediaInfo. The top file is the combined one and the bottom 3 are the ones I joined.
    General
    Complete name : 1.mp4
    Format : MPEG-4
    Codec ID : isom
    File size : 73.2 MiB
    Duration : 3mn 56s
    Overall bit rate : 2 595 Kbps
    Encoded date : UTC 2011-05-26 12:47:36
    Tagged date : UTC 2011-05-26 12:47:36
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 3mn 56s
    Bit rate : 2 437 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Minimum frame rate : 29.960 fps
    Maximum frame rate : 29.980 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.265
    Stream size : 68.7 MiB (94%)
    Encoded date : UTC 2011-05-27 12:19:25
    Tagged date : UTC 2011-05-26 12:47:43
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 3mn 56s
    Bit rate : 156 Kbps
    Nominal bit rate : 136 Kbps
    Maximum bit rate : 170 Kbps
    Stream size : 4.39 MiB (6%)
    General
    Complete name : 100_2508-3.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 7.03 MiB
    Duration : 28s 653ms
    Overall bit rate : 2 058 Kbps
    Tagged date : UTC 2011-05-27 12:19:51
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 28s 595ms
    Bit rate : 1 923 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.209
    Stream size : 6.55 MiB (93%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Bit rate : 136 Kbps
    Stream size : 476 KiB (7%)
    Tagged date : UTC 2011-05-27 12:19:50
    General
    Complete name : 100_2509-4.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 5.37 MiB
    Duration : 14s 349ms
    Overall bit rate : 3 139 Kbps
    Encoded date : UTC 2011-05-27 12:19:51
    Tagged date : UTC 2011-05-27 12:20:05
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 14s 314ms
    Bit rate : 3 003 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.326
    Stream size : 5.12 MiB (95%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Bit rate : 139 Kbps
    Maximum bit rate : 162 Kbps
    Stream size : 243 KiB (4%)
    General
    Complete name : 100_2510-5.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 60.8 MiB
    Duration : 3mn 13s
    Overall bit rate : 2 635 Kbps
    Encoded date : UTC 2011-05-27 12:20:06
    Tagged date : UTC 2011-05-27 12:22:56
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 3mn 13s
    Bit rate : 2 472 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.268
    Stream size : 57.0 MiB (94%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 3mn 13s
    Bit rate : 160 Kbps
    Maximum bit rate : 172 Kbps
    Stream size : 3.69 MiB (6%)
    Oct 2006
    General
    Format : MPEG-4
    Codec ID : isom
    Duration : 3mn 56s
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 3mn 56s
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 3mn 56s
    Bit rate : 156 Kbps
    General
    Format : MPEG-4
    Codec ID : mp42
    Video
    Format : AVC
    Codec ID : avc1
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Bit rate : 136 Kbps
    General
    Format : MPEG-4
    Codec ID : mp42
    Video
    Format : AVC
    Codec ID : avc1
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Bit rate : 139 Kbps
    General
    Format : MPEG-4
    Codec ID : mp42
    Duration : 3mn 13s
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 3mn 13s
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 3mn 13s
    Bit rate : 160 Kbps
