I am in a position where I have to record 1080p video from 9 camcorders for 12 hours a day over the course of 4 days. Ideally, the system would be set up in the morning and turned off at night, but left running throughout the entire day. Does anyone know if it's possible to hook an external hard drive directly to a camcorder? Any make or model is helpful, as I haven't yet purchased the equipment. Would I be better off recording these cameras to a computer? If so, how many computers would be required?
Any and all information is helpful. I have not provided details to equipment because all of the equipment will be purchased pending the solution. Exchanging CF cards or dumping video throughout the day is not a viable option at this time.
Thanks!
Results 1 to 10 of 10
There are camcorders that use internal hard drives to record to. Get 9 of these and spend the night transfering the video to external hard drives attached to a laptop. A laptop with eSATA or USB 3.0 with matching portable hard drives would be best.
What are the camcorders? What format? Are you attempting to record off Firewire or HDMI or analog component?
Focus Firestore makes special hard drives for HDV and DVCProHD cams.
http://www.focusinfo.com/solutions/video_production.asp
For HDMI
http://www.blackmagic-design.com/products/hyperdeckshuttle/
http://www.blackmagic-design.com/products/hyperdeckstudio/
http://www.sounddevices.com/products/pix.htm
http://nofilmschool.com/2011/02/atomos-ninja/
http://www.bhphotovideo.com/c/product/735435-REG/AJA_KI_PRO_MINI_R0_Ki_Pro_Mini_Compact.html
http://www.aja.com/products/kipro/ki-pro-mini/ki-pro-mini-description.php
You should look into renting these if for just one event.Last edited by edDV; 24th May 2011 at 14:52.
http://www.kiva.org/about -
The camcorders and format have not been purchased yet. I'm buying the equipment specifically for this project after figuring out how to do it. I will definitely look into the links you've provided there, so thank you for those. I haven't checked the links yet, but I was under the impression there were no camcorders with hard drives big enough to support 12 hours of continuous HD footage. Am I mistaken?
Renting is not much of a concern right now. I would rather purchase whatever is needed.
Thank you for the help and direction. -
Most of the recorders above use solid state drives to record uncompressed video off the HDMI ports. Uncompressed file sizes will be huge (~425 GB per hour for 1080 60i) so figure 5TB per camera for 12 hours. Double that for 1080 60p.
The only 1080i format that streams compressed is HDV (MPeg2 1440x1080 60i @ 25 Mb/s over Firewire). 25 Mb/s is ~ 13GB/hr or 156 GB for 12 hours.
http://usa.canon.com/cusa/consumer/products/camcorders/consumer_camcorders/vixia_hv40
Other compressed solutions would be in the security cam class.
Another option is HDMI to h.264 hardware encoding.
http://www.bhphotovideo.com/c/product/744366-REG/Teradek_CUBE_220_Cube_220_1_Channel_HDMI.html
http://www.blackmagic-design.com/products/h264prorecorder/Last edited by edDV; 24th May 2011 at 15:11.
Here's one from Sony. 13hr at 28Mb/s top quality mode.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&stor...specificationsRecommends: Kiva.org - Loans that change lives.
I will have power from the wall for all 9 cameras, so I think if one of the Sony HDR models you speak of can give me over 12 hours at 1080p, that is the route I will go. Thank you very much.
Does anyone have experience with this camera? http://www.amazon.com/Panasonic-HDC-HS900K-220GB-Compatible-Camcorder/dp/B004I43MK4
It seems nine of these would do what I need quite nicely, but I want to check first. -
How to record video from camcorder and stream live simultaneously
By bnchs in forum Video Streaming DownloadingReplies: 2Last Post: 27th Aug 2009, 14:28 -
Firefox 3 questions (profiles, RSS feeds)
By Ai Haibara in forum ComputerReplies: 8Last Post: 17th Mar 2009, 06:24 -
Help w Newsgroup feeds a little Off Topic but Id aprpeciate your help
By rotuts in forum MacReplies: 8Last Post: 18th Jun 2008, 09:53 -
RSS Feeds and my browser
By NiteLite in forum ComputerReplies: 8Last Post: 2nd Jan 2008, 21:00 -
What's the point of RSS Feeds?
By TooLFooL in forum ComputerReplies: 6Last Post: 6th Jul 2007, 16:33
