    May 2011
    Los Angeles
    Hello,
    I was wondering if anyone could help me with an FLV conversion.
    I'm looking to get the smallest file possible and still maintain quality.
    It is in slide format so frame rate is not a big deal. However, the slides do need to be clear so quality is.
    I was wondering if anyone could tell me what format and converter would be best for the smallest possible file size.
    Right now, the video is about 50 minutes and 65MB at 630x420.
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    quality is subjective
    what are you trying to do?
    email this?
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Those two don't go together in the same sentence.
    May 2011
    Los Angeles
    Thanks guys,
    Any recommendation on how to make it smaller? I've noticed the sizes varies with different converters on the same settings.
    Maybe a different converter may help?
    Now, I'm using WinX and tried the Digital Media converter. Preferring WinX so far.
    Any others? It's company money so price isn't an issue.
    Thanks!
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Try convert to flv with h264 video. Use for example freemake video converter. Choose to flv and click on settings and change to h264 codec. Try convert to different output file sizes and see how it looks like.
    May 2011
    Los Angeles
    Thanks man,
    I got it down to 1/2 the size. Also the free player works great. Better than all the paid ones I bought.
