Ok, I recorded my daughters dance recital and some of the other parents asked me to record theirs as well. I have a Sony dvd camcoder and have it all on one disc. What I would like to do is cut out the video segments with the other dancers and then put all of those onto one disc for those parents.
I know how to use DVDShrink and use the re-author and cut out a single video segment, but never had to cut out say 3 or 4 and try to put them onto a single dvd. Is there a way to do this? If so, how?
When I use DVDShrink to cut out a single segment and use the backup command DVDShrink makes an AUDIO_TS and VIDEO_TS folder. So thus the reason for my confusion. Don't know how to get three or four separate segments into one disc that way.
HELP appreciated!!!!![]()
Download the demo of Sony Movie Studio HD and load the vob files in there and edit it out that way.
Drag same title several times to the dvd structure in dvd shrink. Then edit each. It wont be a single track though...so not the best solution.
Or you could use mpg2cut2 to cut the dvd vob and then reauthor with something like guifordvdauthor, dvdstyler.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
How do I recombine downloaded video segments
By SheerGold in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2009, 13:12 -
Cropping and combining video segments
By hockeygt975 in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2008, 15:10 -
Errors When Joining Video Segments
By nona in forum EditingReplies: 9Last Post: 15th Feb 2008, 21:40 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 21:45
