Im going to make a cd to play on my dvd. I have a divx cartoon (voltron)that is 45 minutes and 27 seconds long. The size of it is 256 mb. The quality is good and the picture looks good when in full screen with just a little bit of macroblocks. Im going to use TMpgenc 2.02 and an 80 minute cdr; my dvd does not play svcd so; should I make an xvcd with a higher bitrate about 2157 or a regular standard vcd?
Also should i use the soften block noise option and noise reduction and check the high quality mode to limit the macroblocks or will using a higher bitrate help solve that problem? Any suggestion would surely be apreciated.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
