Can anyone tell me how to create an audio cd from the soundtrack of a dvd? 8)
Well -
I'm sure there are a couple of ways to do it -
But I would just rip the DVD .VOBs to your hard drive, then use DVD2AVI, and do a 'save project' and it kicks out the audio in a .wav file for you to use. For best sound, you would want to check to see if there is a 2-channel audio track, and use it. And also have DVD2AVI resample your wave file to 44.1khz instead of 48khz (which I think is the DVD standard)
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 19:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 04:06
