Hello! I just purchased the Pro addition. I found you for my video company and this is an issue for my secretarial company. I get DVDs from a client that contain several interviews with time codes. I typically explore and copy the .VOB files to my hard drive, and work from that. So I thought cool I can just convert into one MPG and have a solid stream of interviews. Well the last interview was cut off, it was contained in the last .VOB4 file. I did check all when I was setting up the conversion. So what's up? Did I miss something?? Thanks!
Results 1 to 1 of 1
Output size for cropped VOB using Cedocida/VirtualDubMod?
By BeckyD in forum Video ConversionReplies: 1Last Post: 9th Jul 2010, 10:01 -
Output file naming in Super Build .38 for .VOB files
By Duwgati in forum Video ConversionReplies: 0Last Post: 2nd Jun 2010, 03:10 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
capture soundcard output stream
By ted demen in forum AudioReplies: 0Last Post: 6th Mar 2009, 20:07 -
screen capture output to dv stream
By bissquitt in forum Video Streaming DownloadingReplies: 12Last Post: 27th Jun 2008, 03:22
