Hi folks,
I use Magix movie edit pro to capture 8mm cam tapes, and lately have begun VHS captures. I use a KWORLD USB 2800D as the capture device. I capture to the Magix native MXV format, which I then normally export as an uncompressed AVI file.
When I check the device options in the capture settings, the MXV format just seems to be a container file, and the actual compression is done by YUY2 (colour space/compression). The thing is you cant pick any other compression codec other than YUY2 when its doing captures.
What do other Magix/non magix users use to capture vid? I would obviously like to capture with as little loss as possible. I know this may mean new software etc.
Cheers.
Results 1 to 1 of 1
Magix Movie Edit Pro 17 - Help
By volotre in forum EditingReplies: 1Last Post: 12th Apr 2011, 12:27 -
Magix Movie Edit Pro 17 for .mts
By Buckskin in forum Video ConversionReplies: 0Last Post: 2nd Oct 2010, 15:51 -
Dropped frames when importing Windows Movie Maker video into Magix edit pro
By gom in forum EditingReplies: 1Last Post: 27th Oct 2008, 11:55 -
Magix Movie Edit Pro and MP4's
By uihawks89 in forum EditingReplies: 2Last Post: 6th Jun 2008, 01:09 -
Moving video edited on Magix movie edit pro 11 to my You Tube account
By Curtis Buck in forum Newbie / General discussionsReplies: 0Last Post: 25th Jun 2007, 19:10
