    May 2011
    Israel
    Hello I am trying to convert MPEG to MKV I use the mkvmerge GUI but I get the following
    error
    Is there any software that converts without prejudice the quality of the movie?
    Try avidemux. Under video and audio choose copy.
    But why? Most stuff supports mpg.
    May 2011
    Israel
    This 1080i MPEG video
    I Want to make it to MKV
    There's another conversion software?
    Thanks for your help
    Did you try avidemux? Open mpg, under video and audio choose copy, save as mkv.
    canada
    Open in tsmuxer and demux,then add the m2v and audio to mkvmerge.
    May 2011
    Israel
    I did a conversion of the software tsmuxer but the movie works slowly (Slow motion)
    And software avidemux I get Crash
    Thanks again for your help
    Jul 2008
    Old Dominion
    You'll want more information about what type of MPEG stream you have, so you might want to check the file with MediaInfo. Have you tried HDConvertToX or MultiAVCHD? Both will convert to Matroska, but since it will require a re-encode you will have some quality loss.
