I have Win7 and Adobe Acrobat Pro X.
If I go to a web page useing IE and a .pdf is suposed to openup within that window - or withn a frame in that window - it won't do it. Instead Acrobat Pro X lanches completely seperately and opens the pdf file as though you had the .pdf file sitting on your desktop and clicked on it. I want it to open the .pdf within the actual IE window or frame.
This does not happen when I use Firfox - just IE. I would like to have both browsers operating properly.
I'm thinking this is some simple setting I am just not figuring out - any help would be appreciated.
Thanks!
it would have to do with the acrobat plugin for that browser. i only use firefox and the plug in v10.0.3.5 there must be one for i.e. for it to work. make sure your i.e. has the plugin enabled if you already have it.
ATi TV Wonder Pro Pci window 7 x64 driver
By Milardo in forum Capturing and VCRReplies: 10Last Post: 12th Feb 2018, 18:04 -
Cant open the pan/crop window in sony vegas 8.0 pro
By Anonymous5494 in forum EditingReplies: 2Last Post: 28th Jun 2009, 02:25 -
How to stop Window Explorer opening when inserting VCD?
By gargoyle_xlvii in forum ComputerReplies: 4Last Post: 21st Feb 2009, 09:03 -
Adobe Acrobat conversion
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 23:27 -
Image Snapshot in Vegas Pro 8 Preview window
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2008, 15:48
