Hello all,
I'm having a problem. Yesterday I decided record videos from my PS3.
I always used to record Virtualdub 32bits. But yesterday he gave me an error:
cannot connect to the desired capture driver
And no longer access my capture cards. I decided to test the Virtualdub64 and to my surprise it worked normally, in power Director 9 964 bit) too.
I already know it is problem with VFW or DSS.
Can someone help me fix this? VD32 = Not Work, VD64= Perfect Record
Windows 7X64, 16Gb, CF 6850, I5, AVERHd, RGC, ISDB Mygica. OS All updated.
Thank you,
Claudio
Reboot? Is VirtualDub trying to connect to the correct device? Device -> (select capture device).
VirtualDub Now Has a Directshow Driver Plugin
By Soopafresh in forum Video ConversionReplies: 57Last Post: 30th Dec 2013, 21:26 -
Bug in VirtualDub (?) -- can't cut desired number of frames
By ralf07 in forum Video ConversionReplies: 3Last Post: 21st Sep 2011, 17:50 -
How to convert .mov (with alpha video 32bits) into .flv with transparency ?
By akinnzip in forum Video ConversionReplies: 1Last Post: 8th Jun 2011, 09:41 -
Canon HF200 - Cannot Connect to Battery Error
By peteyy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Dec 2009, 13:24 -
VirtualDub: "The audio codec cannot compress the source to the desired
By user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 19:35
