I have had no success with displaying output from my oldish Yamakawa DVD-380 player on my brand new Philips 40-in LED TV (model 40PFL6605H) over HDMI.
The TV set insists that there is "no video signal" on the relevant HDMI port. According to the manual of the DVD player, all ports are active simultaneously and do not need to be turned on. The HDMI, DVI and VGA ports should not be used simultaneously. I tried all available digital video OUT resolutions.
With a SCART cable I manage to get an analog picture on port EXT1.
At the time I bought the DVD player, it was noted as not using HDCP over digital video. This was supposed to be a Good Thing (R). Up to now I had used the DVD player with a computer monitor over a DVI -> DVI cable. Could the lack of HDCP support be the problem? Additionally, at the time it came out the DVD player was noted for not working with all brands/models of flat screen TVs over HDMI, but no details were given.
Thanks for any suggestions you might have on getting this to work.
Regards, Couscous
Results 1 to 9 of 9
move up to blu-ray or get another cheap dvd player.
If you have more than one HDMI connector on the tv try another.
I recently acquired a Sony and had a similar issue with one port but not another. -
I've now done two more things:
- Upgraded the DVD player to the latest firmware version 2.81
- Tried all HDMI input ports on the TV
Regards, Couscous
Edit: Tomorrow I will check the HDMI cable by connecting a PC to the TV. -
One other thing.
If you already have a scart from the player to the tv, the HDMI will not work. Don't ask me why but it is one connection only. -
This morning I tried DB83's last suggestion and disconnected the Scart cable before retrying the HDMI connection on all 4 HDMI ports -- no joy.
I also connected a computer via the HDMI cable and immediately got a nice image, so the cable is definitely ok.
So I guess the DVD player is the culprit. It doesn't matter much because I eventually want to move to a "home theater PC" instead of juggling with optical discs all the time.
Thanks for all your help
Couscous
Edit: In the meantime, Scart is suboptimal but acceptable. -
You may need to look at the settngs of the dvd player and see what the output is set for the HDMI port. That needs to match the available sources for the tv - not all are created equally.
So you may find HDMI settings for 576i, 576p, 720i, 720p, 1080i, 1080p.
Scart is sub-optimal but it is also standard definition or analogue.
Maybe your dvd player does not up-scale and the tv is expecting a quasi-HD signal as reported by the source. Even so, it should still receive 576i/p signals. -
Tried that. The player has 3 settings for digital video: 576, 720p and 1080i. None of them work.
I should also mention that last night I updated the DVD player BIOS to the (most recent?) version 2.81. This added a menu item in the setup about "Digital". I suppose it means digital audio because the available options are line and RF.
Cheers
Couscous -
A quote from the manual of your tv:
" If the TV does not recognize the HDMI
device and no picture is displayed, try
switching the source from one device
to another and back again. "
How to make USB video work on Philips LED series 6000 TV
By Joaquim Brasil in forum User guidesReplies: 3Last Post: 14th Sep 2013, 14:58 -
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Connecting HDMI to my apple LED 24" Cinema Display
By dtellez in forum MacReplies: 5Last Post: 5th May 2010, 15:31 -
Philips DVP5990 DTS Via HDMI
By avkhatri in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Jul 2009, 12:33 -
Philips DVP5980 HDMI cable?????
By WhiteEyes in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Oct 2007, 13:32
