I am using AVS Video Editor - saving the video clips (10 dance routines) in .AVI HD 720 -- the quality looks good but they are jumpy. I have to get this resolved today -- I have to finish the video and burn 89 DVDs by tonight...eeek! PLEASE HELP ME!!!!!
Try something better than avs crap. Like the very simple but still good freemake video converter.
And I guess you know that you wont be able to get any real HD from a DVD VOB source.Last edited by Baldrick; 20th May 2011 at 18:09.
Thanks for the advice -- i'm on it! I know it's not real HD - but I need to get these dance videos to be as clear as possible. They are shot from the stands in gymnasiums and are grainy to begin with. So after playing around with different outputs -- that was obviously the best. Again, thank you for the advice.
Terrible decision on your part, since your end output will be DVD, which can only play standard definition, not HD. Your source is already VOB, and all you need to do is extract the MPEG-2 video out of it. Use VOB2MPG for that, then edit the .mpg files and author on DVD. There is no rhyme or reason to do an HD bump up.
Okay -- I obviously am NOT a pro! I was simply comparing the look of the output. It's just not the best video quality to begin with, so I was trying to give it a boost! I have A LOT to learn! Thanks -- I'm looking at your VOB2MPG now! There is not going to be any bump up!!!!!!!!!!!!!!!!!! Thanks for your help!
DVD is jumpy after conversion
By RebelUK in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 29th Jul 2010, 14:04 -
Issue on my conversion of a VOB to AVI
By hygieneboy in forum DVD RippingReplies: 2Last Post: 22nd May 2008, 13:18 -
No video in VOB to AVI conversion
By Matt42 in forum DVD RippingReplies: 12Last Post: 24th Nov 2007, 22:04 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09 -
By famine99 in forum Video ConversionReplies: 0Last Post: 11th Oct 2007, 22:04
