I used my DVDFAB program to rip a DVD to my HDD in the first place and now I want to burn it to a blank disc. Currently, I'm testing out the "Write Data" option but that doesn't seem right to me. What's the correct way of doing this so that my end result is a disc that plays like a DVD?
Results 1 to 9 of 9
I love children, girl children... about 16-40
W.C. Fields -
Oh, and don't worry about the Audio_TS file, there's nothing in it. The Video_TS file is all you need.
W.C. Fields -
If that's a commercial disc, it's probably larger than will fit on a single layer DVD. If so, you can eliminate the extras and it might fit. Or use a dual layer disc, or use something like DVD Shrink to make the file smaller. But I would also recommend ImgBurn.
To author a DVD from ripped content on your hard drive, you select the 'Write Data' option from the menu on the left hand side. Depending on the version of DVD-fab you have, it may be under the 'More...' tab. If you only have the freeware ripping version, this facility may not be enabled.
If you select 'DVD-5' for the quality when ripping it'll automatically shrink the ripped files on the fly so they can be authored to a normal 4.7Gb blank DVD. If you haven't done this you'll need to compress it with DVD Shrink or similar before authoring. -
Audio_TS & Video_TS what they mean exactly?
By Deadmoney in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2011, 11:31 -
very basic question: can I burn a DVD from video_rm & video_ts files?
By glitterla in forum MacReplies: 3Last Post: 25th Feb 2010, 12:09 -
I don't get any movie.DVD folder (audio_TS & video_TS), help!!!
By dbedolla in forum MacReplies: 1Last Post: 10th Nov 2009, 03:21 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 13:39 -
How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
By Crimea in forum Newbie / General discussionsReplies: 6Last Post: 18th Feb 2008, 11:34
