Results 1 to 13 of 13
  1. Hi
    I captured a bunch of tapes using my hp laptop with its capture card using window media center ...and they are reorded as mpeg files
    So now I have to convert them to make dvd ...what is the fastest program to do this
    If there is a way to use this capture card that came with my computer and use a diffrent software that will record to a different format
    Ed
    We were all NEWBIES once and the only stupid question is the one that's not asked?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If your end product is DVD then there is no need to look for alternative capture codecs...DVD is MPEG(2)....it can be nothing else.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    All these years and all those post's and you are still cross/double posting ?!?!
    https://forum.videohelp.com/threads/335145-Capturing-Program
    Hi
    I captured a bunch of tapes using my hp laptop with its capture card using window media center ...and they are recorded as mpeg files
    Is there is a way to use this capture card that came with my computer and use a different software that will record to a different format
  4. Originally Posted by hech54 View Post
    Ok I am new to this but I thougth I had it figured out
    I captured it and want to put it onto a dvd ...don't I need to use a software to et it onto teh dvd and doesn't it take a long time or am I missing something
    I am looking to capture it then drag drop and burn ...again I am new to this
    Thansk
    Ed
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVDFlick and DVDStyler will "author" your DVD for free.
    1) Capture
    2) Author
    3) Burn (preferably with ImgBurn)
  6. Ok so I am not wrong ....I was just hoping to do this quickeram just looking ...Flick took a long time well over an Hr
    Jul 2001
    Then what you captured wasn't to DVD mpeg2 spec or you have DVDFlick re-encoding by default. Use Gspot or MediaInfo on your captured file and compare to 'What is DVD' on the left or post it here for a quick review.
    What is your capture card? What are your video and audio capture settings?
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  8. Well here is what i got from mediainfo ...is this correct format
    General
    Complete name : G:\Transfers\Dance August 1991.mpg
    Format : MPEG-PS
    File size : 3.55 GiB
    Duration : 58mn 11s
    Overall bit rate : 8 731 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=15
    Duration : 58mn 11s
    Bit rate mode : Constant
    Bit rate : 8 000 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.772
    Stream size : 3.32 GiB (94%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Duration : 58mn 11s
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Delay relative to video : -66ms
    Stream size : 160 MiB (4%)
    Aug 2006
    I can see one thing that isn't to spec. For an NTSC DVD, the audio can't be MPEG-1 Layer2 when there is only a single audio track.
    From VideoHelp's "What is DVD"
    Audio:
    48000 Hz
    32 - 1536 kbps
    Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio.
  10. Have a look at this topic
    Jul 2001
    The capture looks fine. (I'd set it to 6000vbr to save space and cut the audio to 192k - unless audio is more important to you - but that's me...) Though not 'spec' per se, I captured tons of OTA, cable and VHS tapes via my ATI AIW using MPEG2 audio. Haven't found a player that wouldn't play it.
    So, your back to what heck54 mentioned in post #5:
    - Capture (you're fine there...)
    - Author (you're basic issue, DVDFlick mentioned, basic and works fine. What you need is something that won't, or that you can tell to not, re-encode.
    - Burn (Take the AUDIO_TS/VIDEO_TS from the Author step and burn to DVD. Use ImgBurn, nothing else...)
    Have a good one,
    neomaine
    Aug 2006
    The problem isn't that DVD players in general won't play MPEG-2 audio with NTSC video. The problem is that some authoring programs could insist on re-encoding the audio to conform to the spec. I don't know if DVDFlick does that or not.
    Jul 2001
    Gotcha... No problem.
    I used to use DVD MovieFactory 2(?) at the time. It had presets that it would re-encode to but also let you setup a custom profile. I would setup a profile with my specs then use that profile to import the capture. Oddly, it was a seperate setting to tell it to ignore (i.e. not re-encode) captures that matched the profile being used.
    Have a good one,
    neomaine
