Hey guys,
I just got a home theatre receiver and I want to hook my PC up to it. My PC's mobo has a SPIDIF output on it (Digital coax, if I'm not mistaken) and the receiver has the same input.....
My question is: what type of cable can be used to go from my PC to Receiver? I was told that I could use a component video cable in a pinch and it would work just as well as a more expensive "HQ audio cable". What do you guys think? What should I go with and where is the best/cheapest place to buy the cable?
A coaxial cable with RCA connectors for the spdif. You don't need any expensive crap.
And for best video quality use hdmi or dvi if you have a such computer output and tv input. -
S/PDIF digital audio coax cable has the same spec as normal 75 ohm composite coax or analog component coax.
http://www.kiva.org/about -
Forgive my ignorance......I think of coax as the screw on cable wire, I've never heard it used in this context. So if I had a long yellow-tip (RCA-video) connector wire, would that work for SPDIF?
My video card has 2 DVI outputs on it, so I thought I'd just use a DVI to HDMI for video. Audio is my main focus though. -
Yes exactly the same spec. RCA to RCA 75 ohm coax (RG 59 or RG 6 or equiv).
In most cases there would be no audio from a display card. Some newer display cards add audio to DVI/HDMI and it will be in the card spec.
Your 8800 GTS may have audio. Spec says it needs S/PDIF into the card.
http://www.nvidia.com/object/product_geforce_8800_gt_us.html
DVI to HDMI via adapter or cable has no performance advantage.Last edited by edDV; 20th May 2011 at 23:59.
PC to Home Theatre
By paulag in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2010, 08:20 -
Home Theatre 'Lite'
By Seeker47 in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2009, 14:39 -
Media center spdif to home stereo
By thearm in forum Media Center PC / MediaCentersReplies: 5Last Post: 8th May 2009, 15:59 -
Question about home theatre projector
By mr-scarface in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 14:44 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
