HELP (please)! Always used to be able to do this (burn a project on to a DVD from TMPGEnc Author 3) but now it keeps telling me to place a disc in the DVD RW when there's one in there already! I also can't get any CDs to play/burn to hard drive through Media Monkey. Any ideas? My DVD RW is an NEC DVD_RW ND-3550A. Thank you! Sally : (
Welcome vhsal
Has to be the number 1 statement out there.Always used to be able to do this
Secondly, what is the media brand being used ?
Next step ... Download imgburn , install, and do a basic test burn to cd or dvd ... any file will do, it's just a test.
Should imgburn also return an error it will be either a media issue or the dvd burner is on its way out (replace)
Only media I use is verbatim's ... very rare if there's an issue. -
Thanks for this, most appreciated!
I use Taiyo Yuden + JVC Premium Grade which seem spot on!
I've downloaded imgburn & tested it out by inserting both a CD & a DVD & it says "medium not present", I think it must be the burner then?!
Am now considering buying a new laptop!! -
That NEC has to have some age on it - I've got three in a duplicator tower because I pulled them from desktop duty (went SATA several years ago). If you've been using that drive - and it's alone in the machine: You've gotten your money's worth.
With drives being cheap these days, it's not an expensive fix.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Happened to me ..exact same model burnt thousands with it....Dead laser.. Cheap as chips to buy a new one these days..
There was a nice Samsung at the egg for $22, LG and others started there and went up.
About 10 IDE model drives available.;/ l ,[____], Its a Jeep thing,
Burning project to disk problem
By NP11073 in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 02:15 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Adding chapters to DVD project in TMPGENC DVD Author
By robertazimmerman in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 11:09 -
Divx Author Project File to DVD?
By grandsire02 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 22:32
