Results 1 to 10 of 10
    Mar 2011
    India
    Hi All,
    Is there any documentation which specifies the max video bit rate upto which FLV can be encoded.
    I tried encoding .flv files using SUPER but video bit rate was not going above 3.6 Mbps.
    So is it a limitation with the tool or this is max which FLV supports.
    Any help will be appreciated.
    Mar 2011
    India
    I am encoding in H264/AVC video format and AAC-LC audio format.
    I doubt that. Try instead freemake video converter. It can convert to flv with h264 directly.
    Mar 2011
    India
    Hi ,
    Thanks for your response.
    I am able to convert with SUPER also that is not an issue.
    But I want to encode my video file at 9Mbps , which SUPER is not allowing.
    Will the tool mentioned by you overcome that limitation.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Yes. You can adjust the bitrate to whatever you like. Just click to FLV and the Edit preset-button.
    Mar 2011
    India
    Thanks for the help. It worked
    Super is a really crappy encoder.
    Jan 2007
    I know this is kind of late, but what do you recommend?
    Something that doesn't take command lines to figure out.
  9. Originally Posted by b8375629 View Post
    See post #3.
    Jan 2007
    There's a lot of controversy about whether Freemake Video Converter is spyware or not.
    Look at the reviews pages where you download it from.
