Hi all, what happens when I'm playing a mkv video that has 6 channels on a computer that has only stereo speakers?
Am I loosing 4 channels? If so, is there a way to select a stereo setting or would I have to convert the file to a stereo setting?
Thanks!
Depends on if you have a "5.1 - to - Dolby Surround/ProLogic/PLII" downconverting plugin somewhere in the playback chain.
Without it, or without a downconverting program, you're losing the 4 other channels.
Scott -
Yeah, those are examples of the "downmixer" plugged into the playback chain...
Scott -
If you can't hear the voices, you are just getting the left and right front with no center in the mix.
http://www.kiva.org/about
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 20:05 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 10:19 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 10:33 -
2.0 stereo vs surround with 2 speakers
By ecc in forum AudioReplies: 8Last Post: 13th Jun 2007, 10:58
