Ok so I know how to use VirtualDub, but I everytime I try to open an FLV file it wont work. Do I need anything to make it work?
You need the FLV source plugin to start.
http://home.comcast.net/~fcchandler/Plugins/FLV/index.html
Put the plugin in VirtualDub's plugins32 folder.
Then you'll need a VFW decoder for whatever video compression is used in the file. And an ACM audio decoder for the audio. ffdshow has VFW decoders for all the types of video used in FLV files. -
fcchandler also has an aacacm for decoding aac audio which is in most newer FLV found on Youtube with H264 video.
You'll also want to install ffdshow and under vfw configuration, choose ffmpeg-mt for H264 and libavcodec for FLV1, Theora, VP3, VP5, VP6, VP6F and VP8.
Here is the link to all of fcchandler's stuff. Everything listed is essential to Virtualdub except for Virtualdub-MPEG2 which is way outdated and with the mpeg2 plugin and ac3acm and ac3 plugin, there isn't much need for.
http://home.comcast.net/~fcchandler/index.html
EDIT: Although this is a great place for help with Virtualdub, you might want to also check out the Virtualdub forum. I visit both of these sites daily.
http://forums.virtualdub.org/
editing mp4 on VirtualDub
By tomchook in forum EditingReplies: 29Last Post: 3rd Nov 2011, 07:52 -
Editing FLV in VirtualDub
By CursedLemon in forum EditingReplies: 12Last Post: 30th Jul 2010, 00:02 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 21:19 -
Editing video with Virtualdub?
By rosmari in forum EditingReplies: 52Last Post: 12th Nov 2009, 08:40 -
Virtualdub, editing out faces?
By capman21 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Mar 2009, 22:12
