Bought this one in Costco and need to open it for playing PAL DVD.
Appreciate any help with instructions how to do it.
Many thanks
Results 1 to 9 of 9
If you live in the USA or Canada there is no hack for you for sure. Most Sony players can't be unlocked anywhere for region free play but a few (not many at all) sold outside of North America have reported to be able to be unlocked. If you want a BluRay player you can unlock do NOT buy Sony or Samsung for sure.
Thanks,
In that case can I buy DVD player and connect it to high def TV to play regular DVDs?? -
http://www.kiva.org/about -
Interesting situation. Our "house" DVD player doesn't do PAL but my Magnavox (and obviously my computer) do.
Not that it is the best, but I simply process the PAL DVD to NTSC for the "house".
I'd like to know if I should expect sync issues with the audio and video.
If so, I will keep original PAL data for myself. Note that I really do need to do the conversion to NTSC for the "house".
I do not think that I can do anything with the Panasonic combo DVD/VHS player. Old model with analog tuner.
The interesting thing is it does play DVD;s recorded on DVD-RAM disks. That was why I bought it back in 2000. -
I accidentally changed the setting for which cable I'm using--how do I get back to the setting screen where I can choose audio/video cable? (Currently frozen on a screen saying I need an HDCI connection.)
Thanks for reply edDV. I just posted a fuller explanation under the DVD heading; here it is: "Trying to get a new Sony DVD player to mesh with an old Sony Trintron TV. I had it set up right using the three-pronged orange-white-yellow audio/video connector. Then I was trying to get rid of the distortion when playing a DVD and accidentally re-set it to use an HDMI connector. Now it's frozen on the screen that says I need that connector--can't get back to the settings screen. Advice"
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Re-programming a Sony BDP-BX58
By Passowilli in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Nov 2011, 10:03 -
Sony BDP-S370: Firmware upgrade to 567 and region free hack
By Nosh3 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jan 2011, 07:57 -
Sony BDP-N460 region hack
By doctorq714 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Dec 2009, 07:32 -
Region-Free hack for Sony BDP-S350 Player
By Megagab99 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd May 2009, 06:14
