Hi Guys,
I have been using this forum for years and have finally plucked up the courage to join!! Apologies in advance if I am asking something really stupid.
Basically, I had a friend who recorded my wedding for me in HDV (tapes) format and he gave me the master copy (the tape). Now basically I dont have access to his camcorder and I need to transfer this into my computer for editing. I have managed to locate a DV camcorder. If I insert the tapes into the DV camcorder it says, HD format not support. My question is can I still use the DV camcorder to transfer the HD tape to my computer.
If the answer is no, it will save me from having to buy a redundant firewire cable.
Many Thanks,
Raz
No. DV camcorder is DV. HDV is mpeg-2 based. Compression is different; data is put to tape in different fashion. One is standard def, the other hi-def. The only thing compatible is the size of the tape cassette.
OK thanks for your help. I have since gone to a shop and asked them to transfer them over.
Thanks for your help.
There werent any other options were there? -
send the tapes to a pro(u can ask for a bluray,or SD copies) cheaper than buying a camera
HDV format outputs 1440x1080i @25 Mb/s MPeg2 TS. Most HDV camcorders can also down convert to DV format 720x480i @25 Mb/s in hardware.
http://www.kiva.org/about -
The OP will need to play the tape in an HDV camcorder or player.
How to import HDV tapes to hard drive for archival
By SteveCA in forum Video ConversionReplies: 16Last Post: 25th Aug 2010, 01:26 -
HDV Playback through camcorder
By 392 in forum EditingReplies: 3Last Post: 6th Nov 2009, 11:43 -
Capturing/editing/ authoring from a Canon HDV HV 40 camcorder
By avz10 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 29th Aug 2009, 01:23 -
how do you work with HDV tapes?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 5th Dec 2007, 23:03 -
HDV tapes
By mikehorne in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 1st Aug 2007, 04:29
