I have the CASIO high speed camera's.
when I am done editing them internally I usually end up with a TON of tiny clips. sometimes it makes sense to just "join" the 20 to 100 4-6 second clips into one video file (there is no audio)
First what is the best tool to do this WITHOUT transcoding. ie direct stream copy. I would love to find something where I can just DUMP a bunch of clips onto it and have it join them for me.
I tried virtualdub (its a pain you have to append EACH video individually 10 ok 100 PITA) but it also does not work.
the resulting video is fine but its 3 times larger than it should be. it seems for whatever reason when I use virtual dub to join these files (640x480 120fps files) it REPLICATES them 3 times each.
ie it plays them all then again then again even though I did NOT tell it to do that. I added each file only once. ???
suggestions?
OK seems I fixed my own problem. AVIdemux seems to work a treat. I can "drop" multiple files onto its window and it "puts them" together and does not have the Vdub duplication issue. works perfectly.
ALWAYS works this way. I spend an hour searching for a solution and only "solve it" after posting about it
merging two video clips together + sync-ing? (with examples!)
By arthritis in forum Newbie / General discussionsReplies: 2Last Post: 18th Sep 2010, 07:23 -
how do I contatinate two clips merging them smoothly? which soft to use?
By grishashvili in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2009, 03:29 -
Simple tool to make video from photos and short clips?
By largactyl in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2008, 12:45 -
Merging AVI Clips
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 26th Nov 2007, 17:10 -
[Solved] Merging clips with different fps and samplerate!!!
By mtamimi in forum Newbie / General discussionsReplies: 3Last Post: 19th Jun 2007, 10:26
