I want to buy a duplicator to duplicate DVD's, but I am bit confusedwith so many brands available? Need Help to make a informed decision!!!
Depends on how many DVDs you need to duplicate and how much you want to spend. Here's a few: http://www.summationtechnology.com/dvd-copier-towers.htm?src=google
Also, do you need printed labels? -
There's a few here that we'd recommend. As Redwuz says, it depends on how much use or automation will be required. We're based in the UK, so I'm not sure what the best deals are closer to you. I'm sure that a quick Google search will come up with something for you.
CD & DVD duplication equipment
I'd avoid printing labels at all costs. They can come unstuck & damage equipment - especially if they're left in a drive & the glue softens etc. You're much better printing on Aquashield discs. Even better get them screen or litho printed, but that again depends on your needs. -
The first one that I owned - I built myself using an Acard duplication card and a case (one - to - one).
The current one I purchased from copystars.com and added the drives (one - to - three).
It came down to the price - the duplication card (Acard) and case were fairly common on the one's that I looked at at the time.
It is and IDE interface, not SATA - so drive replacement may be a problem in the future. At the time, SATA drives hadn't taken over.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Help building DVD Duplicator
By Duvall45 in forum DVD & Blu-ray WritersReplies: 6Last Post: 23rd Aug 2010, 22:53 -
acard dvd duplicator
By johnthedog in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2010, 15:43 -
DVD duplicator help?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 12th Sep 2009, 11:46 -
dvd Duplicator
By kingnat2 in forum DVD RippingReplies: 3Last Post: 28th Jul 2007, 09:49
