I have a movie that is in h.264 / mp4 format. I'm trying to edit out the credits but when I do the resulting file is out of sync. Im not looking to change the codec or anything of the movie, just want to remove the credits
I have Video set to Copy. Audio set to Copy. changed the format to .mp4, or should i leave it at .avi?
Also i get this message when i load the video, should i hit Yes or No?
Results 1 to 19 of 19
yes use that mode, leave the format mp4
You can't cut with frame accuracy, you need to cut on I-frames only . If you don't you can get errors
(you have to navigate with "<<" and ">>" buttons at the bottom) -
Then use the "shift" option under the audio box. 1000 is a second. +/- is the direction.
If the audio de-sync is constant, this will work, but if it's on a curve, you'll have to render the audio out to Wav or PCM first. -
sorry, how do i actually cut the scene? What i usually do is go to the beginning of the scene i want cut, press A (the buttom to the right of ''>>", then go to the end of the scene, press B. Then Edit-->Delete, then save it
ok i think the audi might be on curve how do to render the audio out to Wav or PCM first?
It really is amazing how many times audio is the culprit of a "video problem".
edit:
is there a way to do this without changing the codec of the file?Last edited by Jmart285; 18th May 2011 at 12:06.
When you finish your edit, mux it to whatever you want, keeping in mind that certain ones don't mix. Mux it back to whatever it was before. The repair has already been made.
Use CBR encoding, VBR can cause this kind of stuff.Last edited by budwzr; 18th May 2011 at 12:18.
no saved it as mp4. i might have found a solution tho, http://www.avs4you.com/AVS-Video-ReMaker.aspx
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
avidemux audio out-of-sync problem
By scarlac in forum Video ConversionReplies: 3Last Post: 20th Sep 2010, 11:37 -
after using avidemux, audio is out of sync
By michael12happy in forum Video ConversionReplies: 2Last Post: 26th Apr 2009, 09:48 -
AVIDemux / Video and Audio Out of Sync.
By th3obr0 in forum Video ConversionReplies: 7Last Post: 9th Feb 2009, 11:09 -
AVIDemux 2.4.1 cutting audio or maybe video sync issue
By ColdFusion2 in forum LinuxReplies: 9Last Post: 11th Sep 2008, 10:27
