I have a BlueRay rip of a movie but found that I need audio stream #2 to be the default stream, not audio stream #1. Can this be tweaked in a rip or do I have to re-rip the whole movie?
General
Complete name : O:\Media\Video\Import\MyHomeMovies\BDMV\STREAM\000 00.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 22.2 GiB
Duration : 1h 58mn
Overall bit rate : 26.7 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 27
Duration : 1h 58mn
Bit rate mode : Variable
Bit rate : 23.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.469
Stream size : 19.3 GiB (87%)
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 1h 58mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 327 MiB (1%)
Language : Russian
Audio #2
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Muxing mode : Stream extension
Codec ID : 134
Duration : 1h 58mn
Bit rate : 1 561 Kbps / 1 510 Kbps
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Language : English
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Format profile : Dolby Digital
Codec ID : 129
Duration : 1h 58mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 163 MiB (1%)
Language : English
Audio #4
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 58mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Language : English
+-- Julian Milano
The order of the audio can be set in the authoring stage so you don't need to re-rip,just use the original rip files.
Sorry, I should have explained further. I use the Xtreamer media player at home and what I do is rip my DVD & BD collection to the server then watch them on the Xtreamer in full HD. So the only process is to rip the movie to the HDD then watch it. I've looked at the BD folders and there does not seem to be any editable files where you can change the audio stream priorities and so I was wondering if there is a util to do that. Thanks.
+-- Julian Milano
Including multiple audio streams in rip
By rocks911 in forum DVD RippingReplies: 1Last Post: 9th Dec 2011, 10:39 -
Changing VOB file audio track order
By mmdmmd in forum EditingReplies: 1Last Post: 4th Oct 2009, 16:12 -
Swapping the Audio Streams in a MKV in order to then convert
By JP585 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2008, 05:26 -
Changing the Order of audio on a DVD
By PBoy in forum EditingReplies: 5Last Post: 15th Aug 2008, 01:02 -
Change order of dvd audio streams
By jujuandhuhu in forum AudioReplies: 3Last Post: 18th Mar 2008, 09:19
![Computer details: [Desktop]
Windows 7 x86 Enterprise SP1
Intel Core2 Duo, E6850 3.0 GHz
C:\ = 1TB, D:\ = 5TB
[HP-DV7]
Windows 8 x64 Enterprise SP1
Intel i7, Q740 1.73GHz
C:\ = 750GB, D:\ = 750GB Comp](/images/buttons/computer.gif)
