I want to convert videos to play full-screen on the Nookcolor.I will be using Super by ERightsoft to convert VOB and FLV files.I will be using FreeVideoConverter by Koyotesoft to convert from other file formats.The resolution of the Nookcolor is 854X480 and it expects .MP4. So far,my attempts have come out squashed in the vertical direction and one was stuttering as though the FPS setting wasn't quite right.Does anyone know the settings I should use for these two converters?
Do you have a video that works fine? THen copy those settings. Identify the properties from the video with mediainfo.
You can also try convert with freemake video converter.
Conversion help.
By yugub in forum Video ConversionReplies: 9Last Post: 18th May 2011, 21:45 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 19:36 -
2.35:1 conversion to 1.85:1 (or 1.77:1)
By mgarrido in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 00:21 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 11:46
