  1. Hi. Pasted below are the specs of a file I'm having problems with. So far, only VLC can play it properly but that's no good as I want to play the file on my TV via a HDD media player. I'll need to convert it which I know xmediarecode can do - apparently it was going to take 60 hours so I aborted but the piece it converted was perfect.
    Does anyone know of a tool that would convert this file fairly quickly i.e. less than a day(!)?
    My thanks for any advice or suggestions.
    General
    Complete name : E:\March 2011.mp4
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 1.68 GiB
    Duration : 31mn 21s
    Overall bit rate : 7 659 Kbps
    Encoded date : UTC 2010-10-06 10:36:36
    Tagged date : UTC 2010-10-06 10:37:23
    Writing library : Apple QuickTime
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=24
    Codec ID : avc1
    Duration : 31mn 21s
    Duration_LastFrame : 5h 40mn
    Bit rate mode : Variable
    Bit rate : 6 120 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.118
    Stream size : 1.34 GiB (80%)
    Title : Module de gestion vidŽo / Gestionnaire dÕalias Apple
    Language : English
    Encoded date : UTC 2010-10-06 08:56:54
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 31mn 21s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 345 MiB (20%)
    Title : Module de gestion sonore / Gestionnaire dÕalias Apple
    Language : English
    It's a standard quicktime mp4 with avc/h264 video. Try another all-in-one converter like freemake video converter, format factory, avidemux.
    If they also fails try mpeg streamclip or quicktime pro.
  3. Banned
    Freedonia
    What kind of media player do you have? Just about everything should be able to play that without conversion.
  4. Thanks, Baldrick - I'm downloading freemake and will give that a go.
    jman98 - it's a Western Digital TV Live Hub. It may play the file, I haven't checked. But the file needs editing first and my usual splitters - boilsoft, avidemux - won't do it. That's why I'm trying to convert then edit.
