Results 1 to 9 of 9
    May 2011
    The Great North West
    I downloaded the 2.4 version and 2.5. Neither one can I export a valid file. It only gives me the option to save as "all files" and i get an unrecognizable file exported that I can do nothing with. Please help.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Did you read the other thread you (cross) posted in?....the one with the AviDemux tutorial?
    https://forum.videohelp.com/threads/295782-How-to-get-started-with-avidemux-edit-and-co...=1#post1803481
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Maybe you're doing something wrong.
    May 2011
    yeah but I didnt see a solution to the problem there, any suggestions?
  5. did you specify an extension when saving?
    e.g. "video.avi"
    describe the steps you are using
    May 2011
    e.g. "video.avi"
    I'm not currently on the computer I have the program installed on so I'm goin off the dome here. I import the video then choose the format type from the drop menus on the left side. I hit ctrl+s, when the save dialog box comes up all it allows me to save the file as is "all files". I save it and it leaves an unrecognizble file. any help?
  7. do you have extensions visible on your computer ?
    you need to enter the extension. e.g. if you were using format=>avi on the left side menu. you would use "video.avi" in the save box, then push enter
    if you were using mkv for format, then type in "video.mkv".... I'm sure you get the idea
    May 2011
    Oh serious?????? I didnt know you had to do it manually.I guess I sould have tried that. Thanks man I'll try that when I get home.
  9. You can rename the file you saved already -- just add the extension.
