My SANYO VPC-GH4 records at it's best quality per the manual at 1920x1080 interlaced at 59.94 fields per second. Videoinfo is reporting the file to be progressive at 59.94 frames per second. I was converting to DVD size using the avisynth file:
DirectShowSource("video.mp4")
ConvertToYV12()
LanczosResize(720,480)
But my authoring software is complaining about the frame rate. What do I need to in the avisynth script to convert the frame rate to make the output be compatible with DVD format?
Are the flags in the video file itself not correct and need to be fixed? See the attached small video clip.
You don't need the 'ConvertToYV12' line as it's already in YV12.
I wouldn't use DirectShowSource, if I were you. I used FFVideoSource (the FFMS2.dll).
You can't just resize an interlaced Hi-Def video directly to 720x480 without ruining it. It's interlaced 59.94fps and has to be both resized and converted to 29.97fps. I'm seeing almost all unique frames as having a duplicate, so I'd get the framerate down with a simple SelectEven. I'm having trouble determining the field order since you couldn't have picked a sample with less movement, but this script seems to work:
SelectEven()
AssumeTFF()
Yadif(Mode=1)
LanczosResize(704,480)
AddBorders(8,0,8,0)
SeparateFields()
SelectEvery(4,0,3)
Weave()
There are people around here, though, that know more about these things.Last edited by manono; 16th May 2011 at 08:30.
Thanks,
I added a clip with more motion. I also added the output from mediainfo. mediainfo is showing the video as progressive but the camcorder manual says it should be interlaced. Either mediainfo is providing bad information or the camcorder is not writing the files properly.
What program did you use to verify the video type? Is the file being written by camcorder correctly (i.e. was mediainfo providing incorrect information?).
The seems to be above is selecting every other frame and then deinterlacing the two fields of that frame with Yadif. What is the reason for the seperatefields, selectevery, and weave?Last edited by johnnyquid; 16th May 2011 at 21:01. Reason: clarify question
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 06:38 -
Sanyo VPC-HD2000 with firmware ver 1.2
By phantom8 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Jul 2010, 03:33 -
TV output with SANYO VPC-FH1 limitation
By pjandreu in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Jun 2010, 18:29 -
Sanyo VPC-WH1
By Snakebyte1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Jun 2009, 11:03 -
Video from Sanyo VPC-HD !000
By peterfb in forum Newbie / General discussionsReplies: 1Last Post: 13th Apr 2008, 06:39
