A friend uses his Sony 610 camcorder quite a bit and almost always uses dvd+r dl discs. Recently he was going to continue recording because his camcorder indicated that he still had 37 minutes of recording time left. However, after turning it off and turning it back on a few minutes later, he noticed the camcorder indicated that he had 57 minutes of recording time left, which is essentially a blank disc.
He has tried ISOBuster and CDRoller and both are unable to recover or even see anything on the disc. They both see it as a blank disc. Has anyone had this sort of problem and if so, what software did you use to recover your files?
Any suggestions are appreciated.
1: Swap a blank into the camera and do a test run, remove and shut camera down.
2: Insert bad disc and go through the user manual and confirm if the camera is able to determine sessions ... if so use the camera to finalize the disc first.
Note: If camera unable then do not finalize disc
About the bottom line is a pc lg dvd burner (less picky) and sony vegas combined to recover data ... it's a setup Ive used before to recover problematic discs.
Q: There are two parts to this.
1: dvd+r dl?
What brand exactly was used ... only verbatim is trusted when it comes to DL media
2: "He has tried"
More info ... what is / are the optical drives that have been used for this purpose ... some are junk and make sure his units support + media . -
Brand he is using is MemorexQ: There are two parts to this.
1: dvd+r dl?
The drive he is using is a Plextor PX-800A2: "He has tried"
As for the first part of your reply, I will have to get back to you after I relay the info and get his results.
help recovering DVD folders n vob files from deleted hard drive
By grafixx in forum ComputerReplies: 1Last Post: 16th Jan 2010, 14:44 -
Converting VOB 16:9 Sony Camcorder files to Hard Drive. HELP!! PLS!!!
By llcbh4 in forum Newbie / General discussionsReplies: 19Last Post: 9th Mar 2009, 13:28 -
recovering data from Sony CD Mavica media
By deesto in forum MediaReplies: 4Last Post: 4th Jul 2008, 16:55 -
Recovering damaged dvd files FYI
By Starman* in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2008, 10:32 -
Recovering Video Files from a DVD-R
By Cougar94 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th Mar 2008, 09:09
