    May 2007
    Does ANY company make cd-r's or dvd-r's that are pretty tough against scratches? I remember Office Depot stores carried cd-r's that were supposedly scratch-resistant back about 10 years ago.
  2. Member classfour's Avatar
    The Heartland, United States
    verbatim+95398 NOT readily available - OOS everywhere, including Wal-Mart. VideoGuard.
    I thought Taiyo Yuden had some also - but can't find them.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Feb 2003
    U.S.A.
    Most of the discs with anti-scratch coating these days are the more expensive gold archival grade discs like Delkin Gold with Scratch Armor or Verbatim UltraLife. The only cheap discs that are anti-scratch are Imation Forcefield, but I think they are discontinuing their CD-R media, so get them while you can.
    Feb 2003
    U.S.A.
    Read this: Which discs are scratch resistant?
    That lists discs, and where you can get them for some of the best prices.
    Those are super-crappy discs. Avoid. Do not use. Not suggested.
