  1. Is there way to save a file so when it opens, it ALWAYS opens in the last view you saved it as?
    I have pdf and word doc that always opens at 150%. When I change the view to 75% and save it, I want it to always open at 75% view. But it always opens at 150% view for some reason. I think it is some sort of default and not sure how to change it.
  2. Member DB83's Avatar
    Jul 2007
    Both my pdf readers have a preference setting.
    Taking Adobe as the example edit >> preferences >> documents >> check "Restore last view settings". File will then open at whatever the last view was. Uncheck it and file will open at the last view it was saved.
    Word does appear to open the zoomed view as saved. No preference/setting to change it.
