Ho All
I just started capturing some old videos vhs beta tapes ..with my HP Pavilion Laptop's tuner card ... I am using Windows Vista and Media Center to do this so far I am happy
I came across a tape that that once I was done reorded it split into two files ..it looks like the limitation may be 4 GB but I am looking to make 8 GB dvds
I can't seem to find a setting to change
so here are my questions
1. Is there a hidden setting to change this ?
2. Is there some way of using difrent software ?
3. If yes to Q2 ...any software recommendations ?
I obviously want the best quality
Thanks in advance
Ed
We were all NEWBIES once and the only stupid question is the one that's not asked?
If your hard drive is formatted FAT32 you have a 4 GB file size limitation. The solution to that is to reformat as NTFS. But if you're making movie DVDs that doesn't matter -- DVDs have a 1GB file size limitation. The DVD authoring software will take care of that. The only issue you may have is that some programs won't let you select two source files as one movie.
I highly doubt the hd is ion fat32 and I am confused about the 1 GB file size you mentioned
We were all NEWBIES once and the only stupid question is the one that's not asked? -
There needn't be any doubt: Go to My Computer (or Computer), right click on the drive and select Properties.
The movie DVD spec is very clear: no file may exceed 1 GB. Look at any commercial movie DVD. You will see no files over 1 GB. Movies are typically spread over 4 to 8 1 GB files. When you author a movie DVD the authoring software will take care of this automatically. If you are just writing files to a data DVD this isn't an issue. -
jagoba tahnsk for your help
The HD on my laptop is NTSF...and the reason I said doubt is because this is a fairly new computer (2007) and fat32 and I couldn't tell you the last time I used a fat32 drive
As for the files I am still having issues with these 1.5 to 2 hr tapes. The other 1 hr tapes which have recorded to my HD are just under 4 GB I have no problem with putting them on a DVD
Could it limitations with the software ?? Anyone have suggestions ??
I am now trying to figure out how top merge these ,,,tempgenc keeps saying there is no video stream for part 2
Thansk
EdWe were all NEWBIES once and the only stupid question is the one that's not asked?
Need help for Window/VLC Media Player
By Neil_2004 in forum Video Streaming DownloadingReplies: 2Last Post: 27th Feb 2012, 19:05 -
window media player does not work
By romanstopme in forum ComputerReplies: 8Last Post: 6th Dec 2008, 12:21 -
Window Media Encoder Can't find codecs
By Ensign in forum Video ConversionReplies: 2Last Post: 18th Jul 2008, 11:33 -
Window Media Player and TV
By BobV in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 16:34 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33
