Hi there!
I am capturing video via my Dazzle DVC I. But when i burn them to a CD-R as a VCD format my standalone DVD-Player doesn't play them. But when i burn them to CD-RW,dvd player plays them perfect. It is Sony but i cannot remember the model.But i bought it 2 years ago.. why can this be?
CD-R and CD-RW use different chemicals
CD-RW has a higher reflectivity. It looks more like a DVD than CD-R.
Most Sony Drives dont' play VCD because sony owns a huge motion picture concern. -
i have a sony dvp s360 or something like that
i have yet to try any cdrw but the cdr i use is digital media brand that you can buy from circuit city
any princo cd silver blue -
Originally Posted by Greg12
DVD drives use a different wavelength laser compared to a CD drive. As it turns out, the optics lead to CD-R and CD-RW media being difficult to read. For a DVD drive to be specifically designed to read CD-R or CD-RW media, an additional laser (dual-laser) or specially designed optical system (dual-optics) is required.
DVD drives without this capability are cheaper to produce and presumably this is the reason why many DVD players (not just Sony) can't read CD-R/W properly.
As it turns out CD-RW happens to be more compatible on DVD drives not designed to read CD-R/W which is probably why it but not CD-R works on your player.
Regards.Michael Tam
w: Morsels of Evidence -
I have a Sony dvd player as well and it plays CD-RW's perfectly but has so far rejected any CD-R that I've tried with it which makes me wonder; Are there any CD-R brands (colours) out there that have similar reflective properties as a typical CD-RW that MAY work in this player and others like it?
-Piper
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
