I just want to remove the subtitle track from an .mkv file. I have done this many times before using Yamb , but that converts it to .mp4. I just want to remove the subtitle track without changing the filetype/container format.
So, I want to keep: the AVC and DTS tracks and only remove the "UTF-8 - UTF-8 Plain Text".
I would convert/reencode it to .mp4 but I'm not sure what it would do to the quality.
When the subtitles are embedded like that you cannot turn them off with Windows Media Player and WMP is the only thing I will use.
Download MKVtoolnix and install,load the mkv into mmg.exe,unselect subtitle and save as.
Thank you, that worked. I should have known to use the MKVtoolnix GUI
BATCH remove audio track from mkv
By MarquisdeOz in forum AudioReplies: 53Last Post: 30th Jul 2018, 09:48 -
Link a subtitle with an audio track (MKV)
By Hansio in forum Blu-ray RippingReplies: 0Last Post: 26th Aug 2011, 06:20 -
how to add a subtitle track file to an mkv file???
By Sh@DY in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 20:57 -
Remove subtitle track from mpeg-2
By ehogan in forum MacReplies: 1Last Post: 25th Jan 2008, 21:05 -
Remove subtitle stream from MKV
By NinjaPanda500 in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 15:59
