My Epson R220 has started having problems printing on to discs, about 70% of the discs print ok but the last part of the printing locks up and is all over the place is my printer gone or is this fixable?
thanks.
Two image of the problem:
May simply be an issue with the software ... uninstall all related software and drivers, reboot and reinstall ... retest ... if the result is the same it's likely the control panel in the printer is playing up.
Carefully check the plastic carrier for worn spots and/or evidence of misfeeding. Looks to me like the tail end is slipping. If its the feed gears on the printer itself, or the rollers, you can try cleaning them, ink spatter can cause this kind of thing.
Epson R220 "Service Required"?
By videobread in forum MediaReplies: 25Last Post: 11th Aug 2012, 10:05 -
Epson R220 on the way out. Can nozzles/heads be cleaned? Really?
By videobread in forum MediaReplies: 13Last Post: 12th Jan 2012, 11:56 -
Is Epson R220 now history?
By videobread in forum MediaReplies: 14Last Post: 1st Jul 2008, 13:56 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 25th Jun 2008, 23:58 -
Ink question for refillable Epson R220 cartridges
By Mahime in forum MediaReplies: 3Last Post: 14th Jan 2008, 20:54
