So I'm trying to do some 1280x720 screen capturing using Hypercam.
It seems the only format I can capture in is...full uncompressed frames. Capturing with the Intel IYUV codec produces color distortion, and capturing with the XviD codec results in a video that is sped up while the audio capture remains correctly on sync.
So, that's no problem, I was just going to record uncompressed and then convert with VirtualDub to XviD. Nope, apparently that produces the same exact problem.
XviD behaves perfectly when I'm doing all my DV video conversion...so what is its problem here?
maybe it's the capturing software? have you tried camstudio ?
or maybe you're dropping frames ? what frame rate are you capturing? is your profile up to date ? Athlon64 is older CPU, might be causing problems
recording uncompressed requires large I/O bandwidth; unless you're HDD are setup in Raid-0, you're going to drop frames -
Oh, I'm on an upgraded rig now, i5 with 8GB RAM and an EVGA Geforce GTX 260.
Capturing at 30 FPS, and what about capturing straight with XviD instead of going through uncompressed video? The same problem happens.
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 17:13 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
What screen capping/thumbnails software is this
By Ronny G in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2008, 06:36 -
My computer's screen to DVD Recorder
By mingul in forum Video ConversionReplies: 1Last Post: 14th Nov 2007, 03:27 -
Screen Computer Captures
By Steverup in forum Capturing and VCRReplies: 4Last Post: 5th Jul 2007, 22:02
