I'm trying to do a conversion from DTS to AC3 using AvsP, using the same script I have used a hundred of times. The script is very simple:
nicdtssource("i:\file.dts")
soundout
But I am getting this error message:
"An error occurred while fetching samples.
Current sampleblock will be skipped.
Woud you like to abort conversion."
What error is that and why is it happening?
I extracted the DTS file using MKVextract, as I always do. I even did the extraction again, but I'm getting the same error.
What should I do?
I always convert the DTS files to AC3 because their size is smaller and because sometimes my Blu-ray player refuses to play DTS files.
probably audio is damaged
you can try other source filter e.g. ffaudiosource, directshowsource, but you will probably get same error
you can try converting with eac3to, as it has some repair functions and can patch gaps -
Well, it's been a long time that I loaded my dts file into Eac3to, and the program it's not "coming back".
Which probably means it can't fix the file.
I remember than when you loaded a file on Eac3to it took less than a minute to load it, probably checking it, and opening the choices for you to pick for conversion.
What else can I do? -
Just to put an end to this question. I could find a way out.
At first I thought I could another file with no problem, so I got another one. Same error issues.
So I loaded the file in Xilisoft Video Converter, who saved me on other difficult cases, and used it to convert the DTS file onto a 640K AC3 file.
It went beautiful. No out of sync issues, as I was afraid there might be, and I could merge a new mkv file with everything alright.
Maybe not the purest way, but got me out of the woods.
Avsp won't start
By vidalien in forum EditingReplies: 12Last Post: 14th Mar 2010, 17:04 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
avisynth- AvsP
By deco81 in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2008, 09:39 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
