I got a vob file off my DVD using Isobuster.
I chnaged the extension to mpg.
It plays fine in Windows Media Player both on my XP computer and Win 7 computer.
But, when I try to import it into my video software , it crashes it straight away.
It crashed these:
- Sony Vegas
- Adobe Premier
- Windows DVDMaker
- Windows MovieMaker
But, the mystery (for me) is that it plays fine in Windows Media player, so I have the codecs (right?)
Any ideas?
You have been here 5 years and still do not realise that you simply can not change the .vob extension to .mpg and expect it to work.
Why is it crashing ? Probably because the vob has more than one audio stream or the vob is NOT the complete file with the appropiate mpeg header etc
Basically, you need all the vobs and the ifo file. Then try vob2mpg to extract the mpeg from the vob.
Others may suggest different tools. -
That one's probably the best, and yes it should solve this problem, and also yes you should have already known that.
By MGadAllah in forum EditingReplies: 33Last Post: 25th Sep 2011, 20:53 -
Help! Handbrake crashes shrinking vc1 file
By moggsy in forum Video ConversionReplies: 0Last Post: 13th Dec 2010, 14:49 -
simple free editor to spilt up my MPG2 file?
By Bansaw in forum EditingReplies: 1Last Post: 6th Jul 2009, 10:24 -
Wot the fark is this? I get this popup everytime my cursor touches a video
By jaxxboss in forum ComputerReplies: 6Last Post: 22nd Jun 2008, 10:28 -
Windows crashes if I play an AVI file.
By Captain315 in forum Software PlayingReplies: 8Last Post: 3rd Apr 2008, 22:24
