I'm new at this and want to know how I can convert multiple AVI files into 1 VOB file to burn a DVD.
It's a bit more complicated than just creating a VOB. You might want to look to the upper left on this page for 'WHAT IS' DVD to see the DVD structure, format and specifications.
EDIT: Sorry, I didn't notice this was the ffmpegX forum. But our members here should be able to help you.
And welcome to our forums.
G'day Brendan,
EDIT: Sorry, I made the same mistake as Redwudz. Didn't see this was a FFMPEGX question.
A couple of options spring to mind.
1).. If the AVI's are identical resolutions, codecs etc. you could open them all in AVIMux, extract their elemental streams & re-mux them all back into a single AVI. FAVC will accept the single AVI & author a DVD from it.
2).. You could burn them as individual titles onto a DVD. Again, FAVC will allow this & will create a simple menu structure for them all.
Regards,
Phil.Last edited by The Mariner; 12th May 2011 at 01:49. Reason: Stupidity
1/ Do you want to merge a multi-part movie or just have several short movies on one DVD?
2/ It may be easier or less problematic to convert to DVD compliant mpeg first (using the same settings), and then merge the output files.
3/ For a two-part or three-part movie, I wouldn't merge at all, as this can be solved in the authoring stage, by automatically jumping from the end of part one to the start of part two.
Merging files that have not been creating in one process, may result in problems like glitches and loss of sync. By not merging the source files, this can often be avoided.
Users of the registered version of ffmpegX can use the svcdvd tool to make a DVD from a folder of .mpg files. This would result in a no-menu DVD that plays all segments, one after the other. The order will be based on the alphabetical sorting order of the source files.
easy just get convertxtodvd
it will convert them to vob
and burn them to disc
its a all in one program
Joining Multiple AVI files...
By phorkster in forum EditingReplies: 4Last Post: 13th May 2010, 15:43 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
VOB to Multiple Avi Files
By Idlewild in forum ffmpegX general discussionReplies: 2Last Post: 25th Jan 2008, 01:41 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
