Ok some advice please. I have 3 external burners, with different dvd burner manufacture, Sony,Pioneer,Samsung, plus tow internal dvd bruners, Pioneer, Samsung. I also use Imgburn when i record. Now here is my problem, when i place dvd blanks 8X Taiyo Yuden in each burner and burn different movies(mostly presentations and home movies), the recording write speed is 1.6kb/s to 2.3 kb/s. My desktop is an Alienware Aurora with Velociraptors 300GB 10k, Windows Ultimate 64bit. Is there any way i can record and keep the burning speeds at at least 8x each. If i buy a tower to add these external burners, can i then burn at 8X on each burner or is this impossible. Thanks all.
Ask yourself what is faster.
5 * 1.6 or 1 * 10.5 ?
These are the speeds that you get in a crazy attempt to do the impossible against what you could achieve by just burning a single disk.
It is impossible since the HDD cannot shift enough data quick enough to allow the disks to be written. You do not read of multiple drives at the same time. What makes you think you can write to them ?
A new tower will not help. You can get a disk duplicator but even that is intended for multiple copies of the SAME source and not different ones.
How to Burn at 16 speed or better with 4 burners
By burn master in forum User guidesReplies: 9Last Post: 30th Mar 2010, 20:49 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 22:53 -
Which of the FOUR internal DVD burners is best ?
By MacPCConsultants in forum DVD & Blu-ray WritersReplies: 40Last Post: 29th Nov 2007, 22:56 -
Do internal/external DVD burners have copy protection built in?
By waldothewonderboy in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jul 2007, 00:01 -
External DVD Burners
By offensekilla in forum DVD & Blu-ray WritersReplies: 9Last Post: 12th May 2007, 16:18
