  1. I am having problems finding the Lan drivers for an Asus motherboard.This is info supplied by Speccy..Be very greatfull if someone could direct me to the correct download location or link..Many Thanks
    Windows XP Compaq CPU
    AMD Athlon 64 3500+
    Manufacturer ASUSTek Computer INC.
    Model NODUSM3
    Version 0nx0411RE101NODM300
    Chipset Vendor NVIDIA
    Chipset Model GeForce 6150
    Chipset Revision A2
    Southbridge Vendor NVIDIA
    Southbridge Model nForce 410/430 MCP
    Southbridge Revision A3
    BIOS
    Brand Phoenix Technologies, LTD
    Version 3.07
    Date 08/02/2006
    May 2001
    What does Device Manager say about the LAN device?
    You should be able to get an 8 digit number of the PnP device and then do a search for the vendor. Then go to the vendor's site and download the proper drivers.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  3. the only info avaliable is "1394 net adapter"
    been trying to google an answer...found this would this be it??
  4. That is a firewire port not an actual LAN.
    If there is really an onboard LAN, then yes the NFORCE driver package will usually contain the driver for it.
  5. Very greatfull for the help..i think the second one did it as i had the searching for connection come up in taskbar..Thanks again
  6. I hope you got it sorted out. I've had numerous issues in the past with LAN drivers on NFORCE4 boards. I thought it was just my bad luck but maybe it's just the way they are written.
