D-VHS MPEG2 Transport Stream Capture v0.3.0.6 Problem
I've got the above software and it captures shows that have been recorded in HD through firewire from my HD DVR from Verizon FIOS. I can view those shows with no problem using any of my video players (Nero, realplayer, microsoft). But through the same setup, it won't let me view any shows that were not originally recorded on HD (i.e. those shows that weren't originally broadcast in HD onto my DVR). It creates a .mpg file but I just can't view it.
thank you for your thoughts on this,
Eddie
The tab labled "Data Info" which displays the frame rate, the bit rate, the size and so forth doesn't populate when I press record on the SD movies. I've tried different settings under the settings tab and then i simply start the capturing process by clicking on Rec.. So after I click on Rec., it actually creates an *.mpg file but I can't play that file. I'm begining to wonder if maybe only HD movies come through the firewire while SD movies don't.
The size of the MPG file is anywhere from 8Mb to 1.5Gb because I've tried multiple times.
I haven't tried Vdub? but I think I need to figure out how to get the SD movies to populate the "Data Info" tab.
Also, what settings should I check off under the "Settings" tab if I want the most recognizable mpg format. I don't want to burn blue ray nor HD. I just want to burn regular DVD's -
Why are you posting this multiple times?
https://forum.videohelp.com/threads/334817-Recording-From-HD-DVR-to-PCRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The channels that don't work are likely flagged as Copy Once or Copy Never.
http://en.wikipedia.org/wiki/Copy_Control_Information
HD mpeg2 transport stream re-quantization?
By live4ever in forum DVB / IPTVReplies: 2Last Post: 21st Jul 2009, 19:25 -
Help Please: Looking for MPEG2-ts (Transport Stream) Recovery Software
By Moon43 in forum ComputerReplies: 13Last Post: 11th May 2009, 15:20 -
MPEG2 transport stream software
By PCNG in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 14:10 -
DVD to MPEG2 Transport Stream audio sync problem
By elba in forum Video Streaming DownloadingReplies: 12Last Post: 23rd Oct 2008, 02:09 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06
