Hi,
I live in th UK and have two laptops which I want to be able to play both region2 and region1 DVDs on. I found the patch DVD43 which makes one of my laptops region free but it doesn't work on the other. The one that doesn't work is a Toshiba Portege 500 running Vista and the DVD drive is a Matshita DVD-RAM UJ-844S. I think it is the drive that is the problem. Does anyone know how I might make this one region free too? is there a fix anyone knows about? I've tried a few other packages like AnyDVD and Rioplayer but none have worked.
Thanks chaps. I've tried re-installing AnyDVD and I still have problems. I chose to register/buy later I assume that by doing this you get a trial period to see if it works. It doesn't; it plays only the first two screens i.e. the Copyright page and another general info page and then freezes.
I've also tried the VLC player and it won't play my dvd
Problem with Region Free DVD Player
By The Monkees in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Apr 2010, 07:57 -
region 2 dvd problem
By aprilluis in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2010, 18:47 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 15:48 -
Strange region problem with DVD Shrink re-author
By Jetter68 in forum DVD RippingReplies: 7Last Post: 30th Aug 2008, 14:14 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
