    Feb 2006
    Looking for a program that will back up my insanely large TB's of movies with out doing a disc by disc backup similar to a regular DVD burning program. Where you arrange the media in the burning program and then click a button to burn the files to the DVD. A progam wth an algorithm to arrange the files on a series of discs an then burning them to the disc where all you do is pop in a new black disc.
    Something like a normal backup but with out the need to do a restore the files. The program would allow the playing of the media files from the disc (DVD/CD) itself.
    Similar to this program but doesn't burn the parent folders of the folder that is needed
    http://www.pcmag.com/article2/0,2817,2037102,00.asp
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Not sure what you mean by that....check this just in case:
    http://hcidesign.com/dvdspan/
