Does zipped video file take less time to upload than unzipped file does? If so, should we always zip the video file first before uploading?
Closed Thread
Video compression is complex and ZIP (or RAR) can't improve on it much.
Zipping a video file rarely makes it smaller by more than 1%. So it won't save any time in up or downloading.
However, I prefer to download large files in RAR archives as they can be split into segments, and so if there is an error in one part only that part need be redownloaded. Also extracting a RAR file gives an error check.
Depends on the transfer software and the amount of compression in the target video/audio file.
If the file is low compressed, the transfer software can do additional compression.
Sometimes, highly compressed files expand in response to compression algorithms thus slowing the transfer.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Continue in your similar thread instead https://forum.videohelp.com/threads/334680-Do-you-know-a-good-hosting-site-allowing-bat...=1#post2076886 .
Off topic crap removed.
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 19:32 -
How to extract the ISo from a zipped file.
By sportflyer in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2010, 02:28 -
Does a pre-compressed video file take less time to upload?
By coody in forum Video Streaming DownloadingReplies: 10Last Post: 11th Jun 2009, 23:00 -
Can't upload or convert .FLV file
By fisico23 in forum Video ConversionReplies: 2Last Post: 23rd Jun 2008, 21:58 -
final cut file to upload onto blip
By marinebc11 in forum MacReplies: 1Last Post: 1st May 2008, 11:13
