Hi,
My system suddenly started throwing errors while verifying Double-layered (DVD9) disks after writing.
1. Thinking this was because my Nero 7 was old, I installed Nero 8. Same result.
2. Thinking it was Nero, I installed Roxio 8. Same result.
3. Thinking it was my Disks, I used Imation DVD+R DL instead of SONY. Same result.
4. Thinking it was my recorder, I changed my LG into Liteon. Same result.
No problems with writing ordinary DVD5 disks, though.
I use genuine WindowsXP and have automatic updates. I use 2.66 GHz Intel processor and 1 GB SDRAM.
What's happening?
Thanks and regards.
It starts bad and just gets worse!!
Honestly, after being a member here this long, one would think you would have come across oh about a million post's on this exact same issue!!
And being such an long time member, one would also think you were privy to the super secret search function
But yeah, Verbatim & ImgBurn. -
Whether you should even bother to do those verify scans or not is a whole other subject. I and some others feel pretty strongly that you're wasting your time, but it's your time to waste.
You should follow the Verbatim/ImgBurn advice but if you want to try to have some chance to salvage your crummy DL discs that you bought use ImgBurn to burn them and burn at 2.4x or at most 4x speed. With ImgBurn and lower speed burns you might get them to work OK but you should only buy Verbatim DVD+R DL discs in the future.
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Dvd Lab Pro 2.5 Pre Verification fails / Compile.aux error
By Ultron in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2010, 22:45 -
Can I throw my dvd player away ?
By Brilpat in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2010, 05:54 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 06:51
