Results 1 to 1 of 1
    Sep 2010
    India
    I have been using MeGUI to convert mkv to avi. Lately, after updating MeGUI, I find that it has been crashing and not converting. I do all the steps properly as I'm very familiar with the interface. When I go to the queue tab and press start, the software blinks and stays as 'not responding'. It happens at the first step of converting DTS to AC3 Aften. Please help....
    I use Win 7 Home premium and Trend Micro internet suite.
    [Error] Log for job61 (audio, College Days_Track2.aac -> College Days_Track2.ac3)
    -[Information] [10-05-2011 PM 2:04:43] Started handling job
    -[Information] [10-05-2011 PM 2:04:43] Preprocessing
    -[Information] [10-05-2011 PM 2:04:43] Trying to open the file with NicAudio
    -[Information] [10-05-2011 PM 2:04:43] Failed opening the file with NicAudio()
    -[Information] [10-05-2011 PM 2:04:43] Trying to open the file with FFAudioSource()
    -[Information] [10-05-2011 PM 2:08:21] Successfully opened the file with FFAudioSource()
    -[Information] [10-05-2011 PM 2:08:21] Avisynth script
    --[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll")
    --[NoImage] FFAudioSource("D:\College Days_Track2.aac")
    --[NoImage] Normalize()
    --[NoImage] return last
    -[Information] [10-05-2011 PM 2:08:21] Commandline used: -readtoeof 1 -b 448 - "{0}"
    -[Information] [10-05-2011 PM 2:08:21] Encoding started
    -[Information] [10-05-2011 PM 2:08:21] Avisynth script environment opened
    -[Information] [10-05-2011 PM 2:08:22] Script loaded
    -[Information] Output Decoder
    --[Information] [10-05-2011 PM 2:08:22] Channels: 6
    --[Information] [10-05-2011 PM 2:08:22] Bits per sample: 16
    --[Information] [10-05-2011 PM 2:08:22] Sample rate: 22050
    -[Information] [10-05-2011 PM 2:08:22] Commandline: C:\Program Files\MeGUI\tools\aften\aften.exe -readtoeof 1 -b 448 - "D:\College Days_Track2.ac3"
    -[Information] [10-05-2011 PM 2:08:22] Encoder process started
    -[Error] [10-05-2011 PM 2:08:29] An error occurred
    --[Error] [10-05-2011 PM 2:08:29] Exception message: The pipe has been ended.
    --[Error] [10-05-2011 PM 2:08:29] Stacktrace
    ---[NoImage] at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    ---[NoImage] at System.IO.FileStream.WriteCore(Byte[] buffer, Int32 offset, Int32 count)
    ---[NoImage] at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count)
    ---[NoImage] at MeGUI.AviSynthAudioEncoder.encode()
    --[Error] [10-05-2011 PM 2:08:29] Inner exception: null
    -[Information] [10-05-2011 PM 2:08:29] Output from encoder via stderr
    --[NoImage] Aften: A/52 audio encoder
    --[NoImage] Version git
    --[NoImage] (c) 2006-2009 Justin Ruggles, Prakash Punnoor, et al.
    --[NoImage] input format: Microsoft WAVE Signed 16-bit little-endian 22050 Hz 5.1-channel
    --[NoImage] output format: 22050 Hz 3/2 + LFE
    --[NoImage] invalid bitrate
    --[NoImage] error initializing encoder
    -[Information] [10-05-2011 PM 2:08:30] Job completed
